IFC - Industry Foundation Classes
- Quantification of elements
Subpages
IFC versions
There are currently three commonly supported versions of IFC: IFC2X3, IFC4 and more recently IFC4x3.
IFC formats
.ifc
and .ifczip
sees common usage.
IFC classes
, IfcBuilding
, and IfcTask
can have a Name
class has a Representation
attribute.
Software Libraries for working with IFC
- IFC.js is a javascript library for handling IFC data
- Xeokit is a Web Programming Toolkit for AEC Graphics, including IFC
- IfcOpenShell is a collection of C++ libraries with Python bindings and integration with FreeCAD and Blender
- IFC-dotnet is a C# IFC library for .NET Core under an MIT license (innactive for several years)
- XbimEssentials is a .NET library to work with data in the IFC format. This is the core component of the Xbim Toolkit and under a CPPL license
- GeometryGymIFC C# classes to generate and parse OpenBIM IFC (Industry Foundation Class) files
There is a discussion on the forum comparing some of these libraries. The IfcOpenShell project has done a study to see exactly how much each open source technology currently is capable of scaling.
- The Category:Autodesk Revit links to pages on using IFC in Autodesk Revit
- The Category:Graphisoft_Archicad links to pages on using IFC in ArchiCAD
External Resources
- Which IFC class should I use? help you choose the correct IFC Class for your physical objects.
- IFC Myth Busters
