IFC - Industry Foundation Classes
- Quantification of elements
Subpages
IFC versions
IFC formats
.ifc
and .ifczip
sees common usage.
IFC classes
, IfcBuilding
, and IfcTask
can have a Name
class has a Representation
attribute.
- The Category:Autodesk Revit links to pages on using IFC in Autodesk Revit
- The Category:Graphisoft_Archicad links to pages on using IFC in ArchiCAD
- IFC.js is a javascript library for handling IFC data
- Xeokit is a Web Programming Toolkit for AEC Graphics, including IFC
- IfcOpenShell is a collection of C++ libraries with Python bindings and integration with FreeCAD and Blender
External Resources
