IFC - Industry Foundation Classes
Revision as of 21:48, 14 February 2023 by Duncan (talk | contribs) (→‎See also)
An IFC file being viewed in FreeCAD
  • Physical objects in our built environment (walls, slabs, columns, pipes)
  • 2D and 3D geometry that represents objects or annotate objects
  • A diverse set of properties and attributes spanning many domains
  • Materials attributes and display colours
  • Construction planning, resource allocation, and scheduling
  • Quantification of elements
  • Roles and responsibilities of organisations and individuals
  • Design strategies and legal constraints
  • Analytical models for structural analysis, energy analysis, and light analysis
Subpages[edit]
IFC versions[edit]
There are currently three commonly supported versions of IFC: IFC2X3, IFC4 and more recently IFC4x3.
  • IFC2x3 (typically as Coordination View 2.0 or "CV 2.0") is typically what many BIM authors are used to using to export and exchange models. IFC2X3 has been an ISO standard since 2005.
  • IFC4 has been very slowly implemented in BIM authoring software despite being an ISO standard since 2013. IFC4x contains many new features compared to IFC2X3, such as improved geometry representations, geolocation support, and more element categories.
  • IFC4x3 became an ISO standard in March 2022 and extends IFC4 to be better suited for linear infrastructure (Roads, Railways, Bridges, Earthworks, Geotechnics, Ports & Waterways)
IFC formats[edit]
IFC data is most commonly found in a plain text file format with the file extension .ifc. A common misconception is that IFC is only a intermediate file format. Instead, IFC is a schema, with a full file being only one of many possible ways to store or transfer OpenBIM data. It is possible to transfer portions of OpenBIM data, or full models, using a variety of serialisations. Other serialisations include:
  • .ifc IFC-SPF format, a commonly used plain text format based on STEP
  • .ifczip IfcZIP format, where a single .ifc file is compressed into a ZIP package
  • .ifcxml IfcXML format, a plain text format
  • .json JSON format, a plain text format
  • .hdf HDF5 format, a binary format
  • .sqlite SQLite format, a binary format
In reality, currently only .ifc and .ifczip sees common usage.
IFC classes[edit]
In IFC, a single concept is known as an IFC class. There are hundreds of IFC classes. Examples of IFC classes are IfcWall, IfcBuilding, and IfcTask. Classes can have attributes, for instance, the IfcWall can have a Name attribute. Classes can also have relationships to other classes, for example an IfcWall can be related to an IfcBuilding by being spatially contained within the IfcBuilding.
An example hierarchy of IFC classes
Classes can inherit from other classes, building up a hierarchy of classes. If a class inherits from another class, it inherits all of its attributes and relationships. For example, the IfcProduct class has a Representation attribute, which can store 3D geometry that represents that class. Because the IfcWall class inherits from the IfcProduct class, it also has a Representation attribute to store 3D geometry. However, the IfcPerson class does not inherit from the IfcProduct class, and so it does not have a Representation attribute.
External Resources[edit]
