IFC - Industry Foundation Classes
- Quantification of elements
Subpages
IFC versions
There are currently three commonly supported versions of IFC: IFC2X3, IFC4 and more recently IFC4x3.
IFC formats
.ifc
and .ifczip
sees common usage.
IFC classes
, IfcBuilding
, and IfcTask
can have a Name
class has a Representation
attribute.
- The Category:Autodesk Revit links to pages on using IFC in Autodesk Revit
- The Category:Graphisoft_Archicad links to pages on using IFC in ArchiCAD
External Resources
- Which IFC class should I use? help you choose the correct IFC Class for your physical objects.
- IFC Myth Busters
