IFC - Industry Foundation Classes/IFC classes
class is special because it provides the following four attributes:
GlobalId
OwnerHistory
Name
Description
, IfcBuilding
, and IfcWall
and given a Name
, Name
. They are needed from a technical perspective, and are usually automatically generated by the BIM authoring tool, and can usually be safely ignored by end-users. It is important, however, to know that they exist as power users may encounter them when trying to optimise OpenBIM data.
, or subclasses of IfcRoot
. If a class inherits from another class, or is a subclass of another class, it inherits the same abilities of that class, such as the ability to have certain attributes, properties, or relationships, assigned to it. Subclasses do not actually inherit the values of the attributes themselves, but only the ability to have that attribute.
Subclasses of IfcRoot
IFC Class | Description |
IfcObjectDefinition
These subclasses describe "objects" or "things" that relate to the AEC industry. This includes walls, people, and tasks. You may think of them as the "nouns" in IFC. |
IfcPropertyDefinition
These subclasses describe properties of "objects" and "things". They themselves are not an object, but instead a property or quantity like fire rating, energy usage, or volume. |
IfcRelationship
These subclasses describe relationships between "objects" themselves, between properties, or between objects and properties. The relationships can be objects that contain other objects, connect to objects, have system inputs or outputs, or are assigned a property or quantity. |
Although there are many IFC subclasses, there are only a handful relevant to different BIM authors, and it is useful to provide a summary of them. Underneath these handful are many subclasses which go into more detail, but knowing these broad categorisations exist help with an understanding of IFC data. The following table is not exhaustive.
IfcContext
IfcElement
IfcSpatialElement
IfcElementType
The following non-exhaustive table describes common subclasses used to describe properties, which can later be assigned to objects.
IfcPropertySet
IfcQuantitySet
IfcPropertyTemplateDefinition
If you don't want to actually to store the value of a proprety but instead want to describe a template of what properties exist, which are required, and what data is valid for the purposes of exchange requirements or company standards, then this template subclass allows you to do so. |
IfcPreDefinedPropertySet
Subclasses of IfcRelationship
Although there are many IFC subclasses, there are only a handful relevant to different BIM authors, and it is useful to provide a summary of them. Underneath these handful are many subclasses which go into more detail, but knowing these these broad categorisations exist help with an understanding of IFC data. The following table is not exhaustive.
IfcRelAssigns
IfcRelAssociates
IfcRelConnects
IfcRelDecomposes
IfcRelDefines
A summary of non-rooted elements
IfcMaterial
IfcCartesianPoint
IfcFacetedBrep
A huge variety of geometric forms may be described in IFC. One commonly known format is a faceted BREP, or series of polygons that describe the surface of an object. |
IfcPerson
Information about people and organisations can be recorded, which is especially useful as some countries have legislation that requires this to be stored. |
IfcPropertySingleValue
This commonly used class can define a single property in terms of a property name and its associated value. In addition, there are other classes that allow more complex properties in tabular or calculated form to be stored. |
IfcObjective
This little-known class can store design intentions, strategies, and objectives to be then associated with objects or portions of the BIM model. |
IfcRegularTimeSeries
When scheduling, events may occur at predictable time intervals, which may be stored. |
List of IFC classes
There are multiple versions of IFC in use in the industry, and each version has hundreds of IFC classes. This makes it impractical to describe them in their entirety in a separate community wiki. However, there are some resources available for those who do want a list:
- Hierarchy of IFC2x3 TC1 classes - Hierarchy of IFC4 ADD1 classes
