IfcOpenShell
Tools
IfcConvert
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
Conversion of IFC-SPF data into SpreadsheetML format for the COBie MVD. Includes error logging of invalid data and support for open format alternatives like CSV and ODS.
IFC CSV
Import and export support of IFC data to and from CSV files using a custom IFC query language.
IFC Diff
IFC Patch
Provides a standard interface for users to easily apply predetermined "recipes" to manipulate IFC data without needing to have any technical knowledge.
IFC Sverchok
BIMTester
IfcBlender
IfcMax
An Ifc importer for 3ds Max.
Many software rely on ifcopenshell for their IFC support and more :
- FreeCAD : ifcopenshell-python - import/export
- Tridify (Epic Megagrants recipient)
- BIMServer
- BIMSurfer
- Xeokit-SDK
- BIMData.io
- Areo
- TriDyme
- Augin.app
It is also used in university courses around the world.
Installation
Learn more
External Resources
