IfcOpenShell
Tools
IfcConvert
IfcGeomServer
IfcOpenShell-python
A python API to manipulate IFC. See IfcOpenShell code examples.
IfcBlender
IfcMax
An Ifc importer for 3ds Max.
Many software rely on ifcopenshell for their IFC support and more :
- FreeCAD : ifcopenshell-python - import/export
- Tridify (Epic Megagrants recipient)
- BIMServer
- BIMSurfer
- Xeokit-SDK
- BIMData.io
- Areo
- TriDyme
- Augin.app
It is also used in university courses around the world.
Installation
Learn more
External Resources
