IFC - Industry Foundation Classes
- Quantification of elements
IFC versions
IFC formats
.ifc
and .ifczip
sees common usage.
IFC classes
, IfcBuilding
, and IfcTask
can have a Name
class has a Representation
attribute.
Resources
- The Revit setup page has extensive information on producing good IFC files.
External Resources
