IfcOpenShell
Revision as of 20:50, 15 October 2024 by 1.40.24.243 (talk) (→‎Industry)
Source: github
License: LGPL-3.0 & GPL-3.0
Bugs: Report a bug
Community: Forum
Maturity: Category:Mature
Donate: OpenSourceBIM
Tools
In addition to a developer library, IfcOpenshell can be used through multiple command line tools which can be used independently or together :
bcf-python
IfcConvert
A command line tool to convert IFC to different format including :
.glb glTF Binary glTF v2.0
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
IFC CSV
IFC Diff
IFC Patch
IFC Sverchok
BIMTester
IfcBlender
IfcMax
FOSS projects
  • georeference-ifc Add geoferencing to IFC models
  • IFCGref Visualisation of georeferenced models
  • IfcLCA Lifecycle analysis from IFC data
  • IFC Suite Online simple IFC editing
  • BIMSurfer
Proprietary projects
  • Sortdesk IFC Viewer Used to view IFC files and validate them against IDS specs (using ifctester)
Academia
  • University of South Australia
Industry
BCCV Morocco Tiny Example
bda2bim France Tiny Example
Bylor UK Large Construction
Euskal Trenbide Sarea Spain Medium Construction
Freyssinet Australia Large Engineering
Géo²Concept France Small Example
Geosurv Australia Small Engineering
John Holland Australia Large Construction
Laing O'Rourke Australia Large Construction
Lendlease Australia Large Construction
OpeningDesign USA Tiny Design
Rambøll Denmark Large Engineering
Rail Baltica Estonia, Latvia and Lithuania Medium Operations
SBB Switzerland Large Example
Spectar USA Small Example
TMR (Queensland Department of Transport and Main Roads) Australia Large Operations
Transport for NSW Australia Large Operations
WSP Australia Large Engineering
Installation
External Resources
  • Tutorial and code examples:
