IfcOpenShell
Source: | github |
Bugs: | Report a bug |
Community: | Forum |
Maturity: | Category:Mature |
Donate: | OpenSourceBIM |
Tools[edit]
bcf-python[edit]
IfcConvert[edit]
IfcGeomServer[edit]
IfcOpenShell-python[edit]
IFC Clash[edit]
IFC2CA[edit]
IFC COBie[edit]
IFC CSV[edit]
IFC Diff[edit]
IFC Patch[edit]
IFC Sverchok[edit]
BIMTester[edit]
IfcBlender[edit]
IfcMax[edit]
FOSS projects[edit]
- BIMSurfer
Proprietary projects[edit]
Academia[edit]
Industry[edit]
Installation[edit]
External Resources[edit]
- Tutorial and code examples:
