IfcOpenShell
Source: | github |
Bugs: | Report a bug |
Community: | Forum |
Maturity: | Category:Mature |
Donate: | OpenSourceBIM |
Tools
bcf-python
IfcConvert
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
IFC CSV
IFC Diff
IFC Patch
IFC Sverchok
BIMTester
IfcBlender
IfcMax
FOSS projects
- BIMSurfer
Proprietary projects
Academia
Industry
IfcOpenShell is known to be used in various companies and organisations.
- AF Gruppen Norge AS, Norway
- Bouygues Construction, Australia
- Bylor, UK
- Laing O'Rourke, Australia
- LAB Entreprenør AS, Norway
- Lendlease, Australia
- Norconsult Norge AS, Norway
- OpeningDesign, USA
- Transport for NSW, Australia
- WSP, Australia
- Société des Grands Projets, France
Installation
External Resources
- Tutorial and code examples:
