Free software extensions to proprietary software
CarboLifeCalc | Carbo Life Calculator is the perfect tool to calculate the embodied carbon in a building with a single press of a button. Using data from EPD's or self-defined materials & values, the Carbo Life Calculator automatically interprets your Autodesk® Revit® model and presents you its embodied carbon. See also | MIT |
PyRevit | See also Revit extensions. pyRevit (with lowercase py) is a Rapid Application Prototyping (RAD) environment for Autodesk Revit®. It helps you quickly sketch out your automation and add-on ideas, in whichever language that you are most comfortable with, inside the Revit environment and using its APIs. It also ships with an extensive set of powerful tools that showcase its capabilities as a development environment. See also Revit extensions & PyRevitMEP - MEP Extensions for PyRevit. | GPL-3.0 | |
Relay for Revit | See also Revit extensions. Relay aims to allow you to add Dynamo graphs *(.dyn files)* to your ribbon as push button tools. This is achieved by launching Dynamo in the background (UI-Less) and running the given Dynamo graph. | GPL-3.0-only | |
ArchiCAD | ArchiCAD is a leading commercial BIM authoring software. They have traditionally been supportive of OpenBIM initiatives and early to certify their Industry_Foundation_Classes_(IFC) exports[] | Proprietary |
Autodesk Revit | See also Revit extensions category, Autodesk Revit category & Extensions to proprietary software. Autodesk Revit is leading commercial BIM authoring software. | Proprietary |
