Free software extensions to proprietary software
Although the following software packages are free software, they only operate in conjunction with proprietary software.
pyRevitMEP | See also Revit extensions. PyRevitMEP - MEP Extensions for PyRevit | GPL-3.0 | |
pyRevit | See also Revit extensions. pyRevit (with lowercase py) is a Rapid Application Prototyping (RAD) environment for Autodesk Revit®. It helps you quickly sketch out your automation and add-on ideas, in whichever language that you are most comfortable with, inside the Revit environment and using its APIs. It also ships with an extensive set of powerful tools that showcase its capabilities as a development environment. | GPL-3.0 | |
Autodesk Revit | See also Revit extensions category, Autodesk Revit category & Extensions to proprietary software. Autodesk Revit is leading commercial BIM authoring software. | Proprietary | |
Autodesk Inventor | Autodesk Inventor is a computer-aided design application for 3D mechanical design, simulation, visualization, and documentation. | Proprietary |
