MicroMVDs for exchange requirements
Here is an example of a simple MicroMVD, which checks that an IFC4 file is provided.
These *.feature
schema. The MicroMVD auditing program can then generate a report, which can be used by stakeholers to track whether or not a project is satisfying its requirements.
List of MicroMVDs
- Project setup MicroMVD
- Geolocation MicroMVD
- Model federation MicroMVD
- Element classes MicroMVD
- Geocoding MicroMVD
- Classification MicroMVD
- Geometric detail MicroMVD
- Naming MicroMVD
- Construction types MicroMVD
- Concrete quantity take-off MicroMVD
- Quantity take-off MicroMVD
- Spaces MicroMVD
- Excavation MicroMVD
- Material MicroMVD
- COBie MicroMVD
Auditing BIM data with BlenderBIM Add-on and MicroMVDs
audit.feature
audit.feature
* IFC data must use the "{schema}" schema
- Navigate to your
file.ifc
audit.feature
Execute BIMTester
Modifying a MicroMVD
