IfcOpenShell
Tools
IfcConvert
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
IFC CSV
IFC Diff
IFC Patch
IFC Sverchok
BIMTester
IfcBlender
Superseeded by BlenderBIM Add-on.
IfcMax
FOSS projects
- BIMSurfer
Proprietary projects
Installation
External Resources
