IfcOpenShell
Source: | github |
Bugs: | Report a bug |
Community: | Forum |
Maturity: | Category:Mature |
Donate: | OpenSourceBIM |
Tools
bcf-python
IfcConvert
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
IFC CSV
IFC Diff
IFC Patch
IFC Sverchok
BIMTester
IfcBlender
IfcMax
FOSS projects
- BIMSurfer
Proprietary projects
Installation
External Resources
