IfcOpenShell
[[File:|244px]] | |
Source: | github |
License: | LGPL3.0 |
Bugs: | Report a bug |
Community: | Forum |
Maturity: | [[:Category:Mature]] [[Category:Mature]] |
Donate: | OpenSourceBIM |
Tools
IfcConvert
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
IFC CSV
IFC Diff
IFC Patch
IFC Sverchok
BIMTester
IfcBlender
IfcMax
FOSS projects
- BIMSurfer
Proprietary projects
Installation
External Resources
