IfcOpenShell
Tools
IfcConvert
IfcGeomServer
IfcOpenShell-python
IFC Clash
IFC2CA
IFC COBie
IFC CSV
IFC Diff
IFC Patch
IFC Sverchok
BIMTester
IfcBlender
IfcMax
An Ifc importer for 3ds Max. This plugin seems to not be developed anymore.
FOSS projects
- BIMSurfer
Proprietary projects
Installation
External Resources
