IfcOpenShell
Tools
IfcConvert
IfcGeomServer
IfcOpenShell-python
A python API to manipulate IFC. See IfcOpenShell code examples.
IfcBlender
IfcMax
An Ifc importer for 3ds Max.
Many software rely on ifcopenshell for their IFC support and more :
- BlenderBIM Add-on : ifcopenshell-python - import/export, multi-core geometry processing and more
- FreeCAD : ifcopenshell-python - import/export
Installation
Learn more
External Resources
