Revit setup for OpenBIM
Icon Revit.png This page is Autodesk Revit documentation on implementing OpenBIM. All articles in the OSArch wiki related to Autodesk Revit can be seen in the Category:Autodesk Revit
Subpages[edit]
You can download it here:
See also: IFC classes
Setting up shared parameters[edit]
An example of IFC parameters in Revit
You can download them here:
Setting up psets in Revit
Parameter expression[edit]
For example, to map Revit native Description to IfcRoot.Description you can add an IfcDescription[Type] type parameter and enter value {$this("Description")}.
Revit and IFC GlobalId attributes[edit]
IFC GlobalId values do not exist in a default Revit project file. To create and see the GlobalId select the checkbox shown below select the Store the IFC GUID in an element parameter after export option in File > Export > IFC > Modify Setup > Advanced window, as shown below. It is highly recommended that this option is always enabled.
After your export is complete, you can now see a new parameter called IfcGUID for your objects as shown below. Despite the inconsistent naming, this is actually the IFC GlobalId. This property can now be overridden, copied, or searched for. If the text is deleted, it will be rewritten on your next export. Revit will always rewrite the original GlobalId, with whatever id is written inside Revit. There is no way to automatically regenerate a fresh ID for an existing Revit object, so if it is overwritten is can only be retrieved by finding it manually in the IFC file.
# 1W_HslFTT2WwXj91DxSWxH
Althought it will fail for some elements. Using RevitAPI you can use a function like :
from Autodesk.Revit.DB import ExportUtils, Element
def generate_ifc_guid(element: Element):
    dwf_guid = ExportUtils.GetExportId(doc, element.Id).ToString().replace("-", "")[:32]
    return ifcopenshell.guid.compress(dwf_guid)
External References[edit]
