BlenderBIM Add-on/BlenderBIM Add-on exporting 2D documentation
< BlenderBIM Add-on
Revision as of 00:25, 28 November 2023 by Theoryshaw (talk | contribs) (→‎Drawing Styles and Filters)
Setting up a view[edit]
Selecting an IFC file for a section cut
Left: object without material, Right: object with Blender material named "brick".
Adding annotation[edit]
Dummy annotation objects
Dimensions[edit]
  • Override a dimension
To tag objects:
  • select objects to tag
  • use "Bulk Tag"
  • Metadata:
      • Pset_WallCommon.Status
      • r"Pset_.*Common"
  • Include and Exclude
      • Exclude:
      • Include:
  • Paths to...
    • Stylesheet:
    • Markers:
    • Symbols:
    • Patterns:
    • ShadingStyles:
  • Dimension Rounding
    • MetricPrecision:
    • ImperialPrecision:
  • JoinCriteria
Text Styling[edit]
Top: in Blender setup, Bottom: the result in svg
Exporting a view[edit]
View export options
Background SVG[edit]
External Resources[edit]
Tutorial & Examples
