Revit setup for OpenBIM
Subpages[edit]
IfcGrid
Structural Connections
orIfcFastener
as relevant. Topography
is exported asIfcSite
IfcOpeningElement
IfcMember
, except forJoist
IfcWall
You can download it here:
or IfcGrid
See also: IFC classes
[edit]
group, as shown below.
- The deprecated parameter
IfcSiteGUID
You can download them here:
Parameter expression[edit]
to IfcRoot.Description
Revit and IFC GlobalId
attributes[edit]
IFC GlobalId
, with whatever id is written inside Revit. There is no way to automatically regenerate a fresh ID for an existing Revit object, so if it is overwritten is can only be retrieved by finding it manually in the IFC file.
This UniqueId
and the 8 character ElementId
attribute.
External References[edit]
