Free software libraries for AEC software development
Adapy | Adapy - A python library for structural analysis and design. Adapy is a python library for structural analysis and design that focus on interoperability between IFC and various Finite Element formats. It also provides a neat framework for parametric modelling in python where you not only parameterize your CAD model but also your FEM mesh recipes. | GPL-3.0 | |
Charonifc | Charonifc is a library for extracting text based information from an IFC file to produce technical documentation like Specifications and Bill of Quantities. The program uses IfcOpenShell an open source ([LGPL]) software library for working with the Industry Foundation Classes ([IFC]) file format. | GNU GPL v3 | |
Entwine | Entwine is a data organization library for massive point clouds, designed to conquer datasets of trillions of points as well as desktop-scale point clouds. Entwine can index anything that is PDAL-readable, and can read/write to a variety of sources like S3 or Dropbox. Builds are completely lossless, so no points, metadata, or precision will be discarded even for terabyte-scale datasets. | LGPL-2.0 | |
GeometryGymIFC | C# classes to generate and parse OpenBIM IFC (Industry Foundation Class) files. These classes simultaneously support IFC2x3, IFC4 and Infrastructure proposals for IFC5, and are easily extended for experimental extensions. | MIT | |
IFC-Commenter | A simple script for creating a commented-out hiearchy in an IFC file. There is also a fork by theoryshaw. | MIT | |
libdxfrw | ""libdxfrw is a free C++ library to read and write Drawing Exchange Format (DXF) files in both formats, ascii and binary form. Also can read Drawing_(DWG) files from R14 to the last V2015." It is the default DXF/DWG library for LibreCAD | GPL-3.0 | |
LibreDWG | GNU LibreDWG is a free C library to handle DWG files. It aims to be a free replacement for the OpenDWG libraries. DWG is the native file format of AutoCAD and a number of other CAD packages. | GPL-3.0 |
Nucleus | ".NET Unifying Class Library for Engineering Utility Software. .Nucleus is an open-source .NET library intended as a generalisable base framework for the development of custom BIM and structural engineering workflow tools. It forms the core underlying class system of Salamander 3 and several internal Ramboll software projects." | MIT | |
Open CASCADE | Open CASCADE Technology is a C++ 3D modeling library. It is used to develop CAD/CAM softwares, for instance FreeCAD and IfcOpenShell. | LGPL-2.1 | |
OpenCascade.js | Port of the Open CASCADE CAD library to JavaScript and WebAssembly via Emscripten. | LGPL-2.1 | |
PDAL | PDAL (Point Data Abstraction Library) is a C++ BSD library for translating and manipulating point cloud data. In addition to the library code, PDAL provides a suite of command-line applications that users can conveniently use to process, filter, translate, and query point cloud data. | BSD |
PyFlow | PyFlow is a general purpose visual scripting framework for python. | Apache-2.0 Github | |
pythonocc-core | Pythonocc provides 3D modeling and data exchange features. It is intended to CAD/PDM/PLM and BIM related development. | LGPL-3.0 | |
xeogl | xeogl is an open source JavaScript library from xeolabs for 3D model visualization on WebGL. It gives you tools to create interactive 3D worlds in your browser. Load models from formats like glTF or OBJ, or generate them programmatically. | MIT | |
K3D-Jupyter | K3D lets you create 3D plots backed by WebGL with high-level API (surfaces, isosurfaces, voxels, mesh, cloud points, vtk objects, volume renderer, colormaps, etc). The primary aim of K3D-jupyter is to be easy for use as stand alone package like matplotlib, but also to allow interoperation with existing libraries as VTK. | MIT License | |
LidarView | LidarView performs real-time visualization and easy processing of live captured 3D LiDAR data from Lidar sensors. Runs on Windows, Linux and MacOS. Contrasting to VeloView (that Kitware develops with Velodyne), it provides experimental algorithms and features, but you may expect LidarView to crash in some situations. https://www.paraview.org/lidarview/ | Apache-2.0 License | |
xeokit | xeokit is a Web Programming Toolkit for AEC Graphics and 3D graphics SDK from xeolabs for BIM and AEC. Built to view huge models in the browser. Used by industry leaders. | AGPL-3.0 / dual |
WBFL | WBFL (Washington Bridge Foundation Libraries) provide a foundation upon which to build bridge engineering software applications. Libraries include geometric primitives, section properties, coordinate geometry (COGO), plane frame structural analysis, moving load vehicular live load analysis, and reinforced concrete section analysis. | Alternate Route Library Open Source License |
