Revit setup for OpenBIM
Warning: this page has not been audited for accuracy for Revit versions above 2018 |
Subpages
Setting up IFC class mappings
IfcGrid
Structural Connections
orIfcFastener
as relevant. Topography
is exported asIfcSite
IfcOpeningElement
IfcMember
, except forJoist
IfcWall
You can download it here:
or IfcGrid
See also: IFC classes
group, as shown below.
- The deprecated parameter
IfcSiteGUID
You can download them here:
Parameter expression
to IfcRoot.Description
Revit and IFC GlobalId
attributes
IFC GlobalId
, with whatever id is written inside Revit. There is no way to automatically regenerate a fresh ID for an existing Revit object, so if it is overwritten is can only be retrieved by finding it manually in the IFC file.
This UniqueId
and the 8 character ElementId
attribute.
External References
