FreeCAD
Website: | freecadweb.org |
Source: | Github |
License: | LGPLv2-only |
Bugs: | report bugs |
Community: | Forum Mastodon Twitter Discord |
Donate: | donate |
This is the front page of a series of pages about FreeCAD
Subpages
Introduction
- Featured projects
- BlenderBIM Add-on
- Sweet Home 3d
- Regard3D+Blender+FreeCAD_workflow
- The OSArch Discussion forum has lots of discussions about FreeCAD. You can improve this wiki by turning some of them into pages in this series.
External resources
- Youtube BIM Workbench tutorial playlist in Portuguese (turn on subtitles)
- The BIM Workbench
