Free software extensions to proprietary software
Revision as of 14:30, 14 January 2022 by Duncan (talk | contribs) (→Proprietary software and OpenBIM)
pyRevitMEP | See also Revit extensions. PyRevitMEP - MEP Extensions for PyRevit | GPL-3.0 | |
pyRevit | See also Revit extensions. pyRevit (with lowercase py) is a Rapid Application Prototyping (RAD) environment for Autodesk Revit®. It helps you quickly sketch out your automation and add-on ideas, in whichever language that you are most comfortable with, inside the Revit environment and using its APIs. It also ships with an extensive set of powerful tools that showcase its capabilities as a development environment. | GPL-3.0 | |
ArchiCAD | ArchiCAD is a leading commercial BIM authoring software. They have traditionally been supportive of OpenBIM initiatives and early to certify their Industry_Foundation_Classes_(IFC) exports[] | Proprietary |
Autodesk Revit | See also Revit extensions category, Autodesk Revit category & Extensions to proprietary software. Autodesk Revit is leading commercial BIM authoring software. | Proprietary |
