Revit setup for OpenBIM/Revit IFC project metadata
This page describes how to assign Revit project information to the appropriate IFC classes.
The following attributes may be set on the IfcProject
GlobalId
Yes | Create a new IfcProject GUID instance parameter, assigned to the Project Information object.
Name
Yes | Fill out the Project Number field in the Project Information dialog.
Description
Yes | Create a new IfcDescription instance parameter, assigned to the Project Information object.
ObjectType
Create a new IfcObjectType instance parameter, assigned to the Project Information object.
LongName
Yes | Fill out the Project Name field in the Project Information dialog.
Phase
Fill out the Project Status field in the Project Information dialog.
The properties for an .ifc export are described on the IfcProject entities page of the IFC 2x3 documentation.
