FreeCAD
Website: | freecadweb.org |
Source: | gitlab |
License: | LGPLv2-only |
Bugs: | report bugs |
Community: | Forum Mastodon Twitter Discord |
Donate: | donate |
External pages
- FreeCAD BIM migration guide
- The BIM Workbench
