MicroMVDs for exchange requirements
These *.feature
List of MicroMVDs
- Project setup MicroMVD
- Geolocation MicroMVD
- Model federation MicroMVD
- Element classes MicroMVD
- Geocoding MicroMVD
- Classification MicroMVD
- Geometric detail MicroMVD
- Naming MicroMVD
- Construction types MicroMVD
- Concrete quantity take-off MicroMVD
- Quantity take-off MicroMVD
- Spaces MicroMVD
- Excavation MicroMVD
- Material MicroMVD
- COBie MicroMVD
Auditing BIM data with BlenderBIM Add-on and MicroMVDs
Note: This section is currently out of date (2021-03-19). Please see our forum.
my_first_micromvd.feature
. Note that themyfile.ifc
file.
Execute BIMTester
Modifying a MicroMVD
