Revit setup for OpenBIM
Revit does not come with strong official support for IFC. This guidebook relies on Revit users using the revit-ifc open-source Revit IFC plug-in.
group, as shown below.
You can download the OSArch Revit Shared Parameters File:Revit-sharedparams.txt, which is based off the official Autodesk-provided shared parameters, but contains minor tweaks to accommodate for common Revit workarounds.
A starting template for Revit user defined psets can be found here: File:Revit-psets.txt
Revit and IFC GlobalId
attributes
IFC GlobalId
values are not visible in Revit by default. This becomes problematic if users are trying to reference an object by its ID. The only way to see the GlobalId is to export your Revit model to an IFC file with the Store the IFC GUID in an element parameter after export
option enabled in File > Export > IFC > Modify Setup > Advanced
. This property can now be overridden, copied, or searched for. If the text is deleted, it will be rewritten on your next export. However, it will always rewrite the original GlobalId
, as it is predetermined inside Revit. There is no way to regenerate a fresh ID for an existing Revit object.
This UniqueId
and the 8 character ElementId
attribute.
