IfcOpenShell code examples
Crash course
. The ifc
will be then used throughout.
import ifcopenshell
import ifcopenshell
With that opened IFC file, it is possible to iterate through entire file using a simple loop. It gives you an access to each of STEP ID item. Later on you can have more elaborate and more detailed queries about your IFC file.
for entity in model:
print(entity)
print(ifc.by_id(1))
value instead?
print(len(walls))
print(wall.id())
print(wall.GlobalId)
print(wall.Name)
import ifcopenshell.util
print(wall.IsDefinedBy)
print(ifc.get_inverse(wall))
print(ifc.traverse(wall))
s:
ifc = ifcopenshell.file()
ifc.create_entity('IfcWall')
data = {
'Name': 'Wall Name'
new_ifc = ifcopenshell.file()
new_ifc.add(wall)
ifc.remove(wall)
Geometry processing
function to convert an element into vertices, edges, and faces.
import ifcopenshell
import ifcopenshell.geom
import multiprocessing
import ifcopenshell
try:
except:
print(ifcopenshell.get_log())
else:
if iterator.initialize():
while True:
shape = iterator.get()
if not iterator.next():
break
Geometry tree (clash detection/ray tracing etc…)
IFC Query Syntax
and if
statements, and for
module.
and .
selector = Selector()
symbol, for example:
Or by type using the *
symbol:
You can use AND
and OR
statements, using the &
and |
symbols respectively:
Exploring IFC schema
Get Schema :
import ifcopenshell
Explore class attributes :
>>> ifc_pipe.all_attributes()
9
3
>>> predefined_type.name()
'PredefinedType'
True
'IfcPipeSegmentTypeEnum'
Get supertype :
>>> ifc_pipe.supertype()
<entity IfcFlowSegment>
Another way to get a list of supertypes :
>>> import ifcopenshell
>>> inheritance = []
>>> while e.supertype():
... inheritance.append(e.supertype())
... e = e.supertype()
>>> inheritance
Get subtypes :
>>> super_type.subtypes()
<entity IfcCableSegment>,
<entity IfcDuctSegment>,
<entity IfcPipeSegment>)
['Pset_MaterialCombustion',
'Pset_MaterialCommon',
'Pset_MaterialConcrete',
'Pset_MaterialEnergy',
'Pset_MaterialFuel',
'Pset_MaterialHygroscopic',
'Pset_MaterialMechanical',
'Pset_MaterialOptical',
'Pset_MaterialSteel',
'Pset_MaterialThermal',
'Pset_MaterialWater',
'Pset_MaterialWood',
'Pset_MaterialWoodBasedBeam',
>>> pset_template
>>> pset_template.get_info()
{'id': 22772,
'OwnerHistory': None,
File validation
From command line
On GNU/Linux you can store result in a json file:
python -m ifcopenshell.validate --json some_file.ifc >> json_output_path.json
Inside a script
import ifcopenshell
import ifcopenshell.validate
json_logger.statements
Date and time in IFC
IfcTimeStamp
import time
# To store current time
>>>int(time.time())
1610829915
>>> import datetime
IfcDateTime
from datetime import datetime
>>> dt
>>> dt.isoformat()
'2021-01-16T21:45:15'
IfcDate
You can use datetime.date
instead of datetime.datetime
the same way.
IfcTime
You can use datetime.time
the same way.
IfcDuration
>>> import re
IfcCalendarDate
Similar to IfcDate
>>> import ifcopenshell
>>> py_date
datetime.date(2021, 1, 16)
#4=IfcCalendarDate(16,1,2021)
Samples from web
