PyRevit
Revision as of 09:02, 15 January 2024 by 89.102.71.104 (talk) (pyRevit Rapid Application Development and Tools for Revit)
PyRevit.svg
pyRevit is a Revit add-on, which let's users easily build their own Revit add-ons (Python, C#, DynamoBIM, Grasshopper, ...) without much build plate code or any Revit restarts, which allows for rapid development and convenient deployment.
Resources
From their GitHub page
pyRevit helps you quickly sketch out your automation and addon ideas, in whichever language that you are most comfortable with, inside the Revit environment and using its APIs. It also ships with an extensive set of powerful tools that showcase its capabilities as a development environment. Download and install pyRevit, launch Revit, and note the new pyRevit tab that includes these tools. pyRevit also ships with a handy CLI utility for customized configuration and deployment of your tools, and a telemetry server to monitor pyRevit usage across your teams.
pyRevit can help you:
  • Add a powerful set of free tools to your Revit workflows.
  • Sketch out your automation ideas quickly in python
  • Write your own Revit addons for Revit using python (IronPython or CPython), C#, VB.Net
  • Distribute your tools (pyRevit, Dynamo, or Grasshopper) easily to your teams using a unified interface
  • Share your tools with the community
Share Your Coins
↓ Help making pyRevit financially stronger
Support on Patreon
Supporters
Contributors
https://github.com/eirannejad/pyRevit/graphs/contributors
</> with 🖤 in Portland, Oregon
Copyright © 2014-2023 by Ehsan Iran-Nejad (pyrevitlabs.io) - All Rights Reserved
Extensions
pyRevit comes loaded with optional tools and extensions
  • pyRevitMEP is a pyRevit Extension (by OSArch supporter Cyril Waechter) which include tools dedicated to MEP task in Revit. It can connect to the materialsdb database.
  • pyChilizer by the team @ Archilizer
  • EF-Tools by Erik Fritz from Learn Revit API
  • Revitron by Marc Anton Dahmen
  • pyTiBa by Till Baumeister
  • and many other
License: GPL3
This page describes a software project from our AEC Free Software directory
