IfcOpenShell code examples
Crash course
. The ifc
will be then used throughout.
import ifcopenshell
print(ifc.by_id(1))
value instead?
print(len(walls))
print(wall.id())
print(wall.GlobalId)
print(wall.Name)
import ifcopenshell.util
print(wall.IsDefinedBy)
print(ifc.get_inverse(wall))
print(ifc.traverse(wall))
s:
ifc = ifcopenshell.file()
ifc.create_entity('IfcWall')
data = {
'Name': 'Wall Name'
new_ifc = ifcopenshell.file()
new_ifc.add(wall)
ifc.remove(wall)
Geometry processing
import multiprocessing
import ifcopenshell
import ifcopenshell.geom
try:
except:
print(ifcopenshell.get_log())
else:
if iterator.initialize():
while iterator.next():
shape = iterator.get()
IFC Query Syntax
and if
statements, and for
module.
and .
selector = Selector()
symbol, for example:
Or by type using the *
symbol:
You can use AND
and OR
statements, using the &
and |
symbols respectively:
Exploring IFC schema
Get Schema :
import ifcopenshell
Explore class attributes :
>>> ifc_pipe.all_attributes()
9
3
>>> predefined_type.name()
'PredefinedType'
True
'IfcPipeSegmentTypeEnum'
Get supertype :
>>> ifc_pipe.supertype()
<entity IfcFlowSegment>
Get subtypes :
>>> super_type.subtypes()
<entity IfcCableSegment>,
<entity IfcDuctSegment>,
<entity IfcPipeSegment>)
['Pset_MaterialCombustion',
'Pset_MaterialCommon',
'Pset_MaterialConcrete',
'Pset_MaterialEnergy',
'Pset_MaterialFuel',
'Pset_MaterialHygroscopic',
'Pset_MaterialMechanical',
'Pset_MaterialOptical',
'Pset_MaterialSteel',
'Pset_MaterialThermal',
'Pset_MaterialWater',
'Pset_MaterialWood',
'Pset_MaterialWoodBasedBeam',
>>> pset_template
>>> pset_template.get_info()
{'id': 22772,
'OwnerHistory': None,
Date and time in IFC
IfcTimeStamp
import time
# To store current time
>>>int(time.time())
1610829915
>>> import datetime
IfcDateTime
from datetime import datetime
>>> dt
>>> dt.isoformat()
'2021-01-16T21:45:15'
IfcDate
You can use datetime.date
instead of datetime.datetime
the same way.
IfcTime
You can use datetime.time
the same way.
IfcDuration
>>> import re
IfcCalendarDate
Similar to IfcDate
>>> import ifcopenshell
>>> py_date
datetime.date(2021, 1, 16)
#4=IfcCalendarDate(16,1,2021)
Samples from web
