IFC - Industry Foundation Classes/IFC concepts/IFC sequence concepts
- IfcWorkCalendar
- IfcWorkControl
- IfcWorkPlan
- IfcWorkSchedule
- IfcRelSequence
- IfcTask
- IfcTaskTime
- IfcLagTime
- IfcTaskType
- IfcEvent
- IfcProcedure
Source: IfcWorkSchedule
A project may contain tasks
Source: IfcWorkPlan
A work plan may contain tasks
Source: IfcWorkPlan
In construction scheduling, a work schedule can represent your current plan of tasks, prior to the start of construction. A planned schedule typically has scheduled start, finish, and durations for its tasks. A planned schedule must not have any actual starts, actual finishes, or actual duration data.
A work schedule may be labeled as an actual schedule, if it contains actual start / end dates of tasks, and actual durations of tasks.
A task may contain subtasks
Source: IfcTask
Source: IfcTaskTime
Source: IfcTask
Source: IfcProcess
Tasks may consume resources
A task consumes resources.
A task request may result in a project order being created =
Source: IfcTask
