IFC - Industry Foundation Classes/IFC concepts/IFC sequence concepts
- IfcWorkCalendar
- IfcWorkControl
- IfcWorkPlan
- IfcWorkSchedule
- IfcRelSequence
- IfcTask
- IfcTaskTime
- IfcLagTime
- IfcTaskType
- IfcEvent
- IfcProcedure
Source: IfcWorkPlan
Source: IfcWorkSchedule
Note: we are unsure what is the purpose of directly assigning work schedules to the project. It makes more sense to group it within an IfcWorkPlan, which acts as a distinguishing factor between work schedules used for sequencing, compared to facility management, or other currently unknown purposes (perhaps, safety routine checks?). We think this relationship should be removed.
Source: IfcWorkPlan
In construction scheduling, a work schedule can represent your current plan of tasks, prior to the start of construction. A planned schedule typically has scheduled start, finish, and durations for its tasks. A planned schedule must not have any actual starts, actual finishes, or actual duration data.
A work schedule may be labeled as an actual schedule, if it contains actual start / end dates of tasks, and actual durations of tasks.
A project may contain tasks
A task may contain subtasks
A task may be assigned a calendar, determining when that task can occur
A task without a calendar inherits the calendar from a parent task
A calendar may be a child of a parent calendar. The exception times of the child calendar will first inherit, and then override the availability of its parent calendar.
