BlenderBIM Add-on/BlenderBIM Add-on exporting 2D documentation
2D Construction Documentation
Setting up a view
Selecting geometry to be cut
Defining drawing appearance
As mentioned earlier, the resulting SVG file gets its final appearance from the style sheet, defined in the Project data directory. The CSS controls the appearance using classes, which means that by assigning an arbitrary class, any group of objects can be assigned a specific appearance. Some of the classes are defined as an example in the PROJECT_DATA_DIRECTORY⁄styles⁄default.CSS
, defining the appearance of the annotation elements added through UI (see below) and some basic material hatches.
The symbols and hatches referenced by the CSS file are standard SVG files stored in PROJECT_DATA_DIRECTORY⁄templates⁄
The predefined material classes are assigned automatically to all objects, based on the name of their Blender material. As an example, when no material is defined, the section hatch in SVG is the default black. By assigning a material named named brick
(case sensitive!) to an object, its resulting hatch in SVG changes in two parallel diagonal lines. Note that it is's blender material name if your object's material is IfcMaterial. If it's not IfcMaterial (for example if it's IfcMaterialLayerSet) then brick
should be IfcMaterialLayerSet's name.
There are more patterns for materials you can find in blenderbim\bim\data\assets\patterns.svg that comes with BlenderBIM. Patterns like crosshatch1
, crosshatch2
, crosshatch3
, sand
, grass
, etc. You can also define your own patterns in the similar manner.
Adding annotation
- Curve - IfcAnnotation/Dimension.Number - as a dimension
- Curve - IfcAnnotation/Equal.Number - as a dimension with the letters EQ instead of its value
- Curve - IfcAnnotation/Leader.Number - as a label with a leader arrow symbol
- Curve - IfcAnnotation/Stair.Number - as a staircase arrow symbol
- Curve - IfcAnnotation/Section Level - as a section elevation dimension with an arrow symbol
- Curve - IfcAnnotation/Plan Level - as plan elevation dimension with a crosshair symbol
- Mesh - IfcAnnotation/Hidden.Number - as a dashed curve
- Text - IfcAnnotation/Text.Number - as a text field
- Curve - IfcAnnotation/Fall - indicate slope on a ramp, for example
Dimensions
- Override a dimension
- Set the Description attribute of that dimension. This means that that dimension needs to be separate from other dimensions.
- Add BBIM_Dimension pset and enable "DescriptionOnly". Otherwise the description is shown in addition, instead of replacing the dimension.
Intelligent Tagging of Objects
To tag objects:
- select Annotation Tool choose annotation type
- select objects to tag
- use "Bulk Tag"
- Text tagging - will create IfcAnnotation of type Text at the center of the object then you can refer to the tagged object properties in the text. More.
- Stair Arrow tagging - will create stair arrow by the stair X axis going until the last stair step. Example.
Drawing Styles and Filters
- Metadata:
- For example add property you'd like to be exported to SVG class. Examples
Pset_WallCommon.Status
r"Pset_.*Common"
- Will attach a class like the following to the SVG object
rPsetCommon-StatusEXISTINGDEMOLISHid68585
- Example of how a css regular expression to style the svg
[class*="PsetCommon-StatusEXISTINGDEMOLISH"] { fill: url(#demolish); stroke: red; stroke-dasharray: 2, 1; }
- Include and Exclude
- In the Include and Exclude property you can indicate what to include/exclude from the drawing. A few examples.
- Exclude:
IfcElement , /Pset_.*Common/.Status=DEMOLISH
IfcElement , /Pset_.*Common/.Status=NEW
IfcElement , EPset_Status.Status=DEMOLISH
- Include:
only show demo.IfcElement , /Pset_.*Common/.Status=NEW
only show new.
- Exclude:
- Paths to...
- Stylesheet:
- defaults to:
drawings/assets/default.css
- defaults to:
- Markers:
- defaults to:
drawings/assets/markers.svg
- defaults to:
- Symbols:
- defaults to:
drawings/assets/symbols.svg
- defaults to:
- Patterns:
- defaults to:
drawings/assets/patterns.svg
- defaults to:
- ShadingStyles:
- defaults to:
drawings/assets/shading_styles.json
- defaults to:
- Stylesheet:
- Dimension Rounding
- MetricPrecision:
- ImperialPrecision:
- Example:
1/2
rounds to the nearest 1/2"
- Example:
- JoinCriteria
- If no JoinCriteria is given, it defaults to unjoin the following things
["class", "material.Name", 'r"Pset.*Common"."Status"']
. If you want to unjoin justmaterial.Name
, for example, set JoinCriteria value to:material.Name
Text Styling
- Background for Ifc Text annotations in SVG
Exporting a view
- Should Recut - a vector image is generated by intersecting a plane parallel to the camera plane in camera origin with geometry of the ifc files selected in Output Properties > Documentation.
- Should Render - a raster image is generated by rendering the current Blender model with the current camera
- Should Extract - metadata from the IFC file, such as material or property data (such as in smart annotations), are re-extracted
Creating schedules and adding them to a sheet
Background SVG
Copying Annotation from one drawing to another
Settings in Blender Preferences - Add-ons
- SVG to PDF Command:
- Windows Examples:
[["inkscape.exe", "svg", "-o", "pdf"]]
- If you want to set the DPI
[["inkscape.exe", "svg", "-o", "pdf", "--export-dpi=300"]]
- Windows Examples:
- SVG Command:
Updating from older Drawing System
External Resources
Tutorial & Examples
- Creating drawings - BlenderBIM Add-on 200912 Technical WIP Demo - September 12, 2020
- IFC OpenBIM SVG construction documentation - 200620 BlenderBIM Add-on Technical WIP Demo - June 23, 2020
- Housing alteration design documentation with BlenderBIM Add-on
- The Revit office building as pure IFC documentation
- Examples of floor plans derived from IFC
