FreeCAD
Revision as of 14:53, 5 November 2023 by Bitacovir (talk | contribs) (→‎Introduction: add a link to macros page)
Website: freecadweb.org
Source: Github
License: LGPLv2-only
Bugs: report bugs
Community: Forum Mastodon Twitter Discord FreeCAD News Blog
Maturity: Category:Functional
Donate: donate
This is the front page of a series of pages about FreeCAD
Subpages
Introduction
FreeCAD uses the Open CASCADE modelling kernel for the creation of 2D and 3D shapes, and is divided into "workbenches" that provide tools for specific domains.
  • Part and PartDesign Workbenches provide tools for the creation of generic 3D models.
  • Sketcher Workbench provides tools to create mathematically constrained 2D sketches that can be used for extrusion in Part and PartDesign.
  • Draft Workbench provides tools to create parametric 2D objects in a plane.
  • Arch Workbench builds on top of Draft, to create parametric 3D solids used in architecture, like walls, pillars, rebars, windows, doors, and roofs.
  • TechDraw Workbench provides tools to create 2D projections of arbitrary 3D bodies in order to create technical drawings and documentation that can be exported as PDF.
  • Reinforcement workbench is an external workbench that provides tools for Reinforcement Generation and Detailing. This workbench provides an interface and presets for the creation of common rebar types.
  • The BIM Workbench builds on top of Draft and Arch, and provides even more tools for building modelling.
  • The Reinforcement Workbench extends the rebar tools of the Arch workbench to create even more complex rebar patterns.
External resources
This page describes a software project from our AEC Free Software directory
Icon FreeCAD.png This page is FreeCAD documentation. Full documentation is available at the FreeCAD documentation wiki. All articles in the OSArch wiki related to FreeCAD can be seen in the FreeCAD Category
