Revit setup for OpenBIM/Revit IFC geolocation
From Revit IFC 19.4.0.0 / 20.2.0.0 / 21.1.0.0
Native input of global coordinates has been implemented in Revit IFC 19.4.0.0 / 20.2.0.0 / 21.1.0.0. Although only for IFC4.
Set coordinates
Specify your Project Base Point
coordinates according to data given by your surveyor :
Your Project Base Point
should not move relatively to your building / elements. You might also want to apply coordinates to Survey Point
to keep both at same location.
Alternatively, you can unclip Survey Point
, set coordinates in properties, re-clip it then move it to your Project Base Point
. You still need to set angle to north in Project Base Point
You will also need to set the combined scale factor. This scale factor * surface distance = grid distance. Sometimes, surveyors will give you the opposite. The scale factor will be close to 1. Then, download the Revit IFC shared parameters file, and add ProjectGlobalPositioning.Scale as a project parameter and make it apply to the Project Information category as an Instance parameter grouped under the "IFC Parameters" group. Insert the scale factor in the Project Information dialog when done.
Specify global positioning information during export
- Modify your export setup
- Select
Coordinate Base
->Project Base Point
- Input
EPSG Code
. It should be a valid EPSG number see EPSG website or ask your surveyor.
Result
You should see an IfcMapConversion
in your ifc file after export under IfcProject.RepresentationContexts[0].HasCoordinateOperation[0]
Before Revit IFC 19.4.0.0 / 20.2.0.0 / 21.1.0.0
, E/W
, Elev
, and Angle to True North
and Survey Point
and the Survey Point
is the same.
IFC2X3 Geolocation
This Toposurface
Property Name | Required |
EPset_ProjectedCRS.Name
Yes |
EPset_ProjectedCRS.MapZone
EPset_ProjectedCRS.MapUnit
EPset_MapConversion.Eastings
Yes |
EPset_MapConversion.Northings
Yes |
Yes |
Yes |
Yes |
EPset_MapConversion.Scale
Yes |
IFC4 Geolocation
will be blank as it is not yet implemented in Revits exporter.
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
IFC2X3 and IFC4 geolocation patching
of the IfcSite
of the IfcBuilding
recipe:
is the Orthogonalheight
IFC2X3 and IFC4 geolocation reference information
To store the RefLatitude
and RefLongitude
correctly in the IfcSite
When the Search
attribute of the IfcSite
is the value you want to set.
or ElevationOfTerrain
attributes of the IfcBuilding
