Revit setup for OpenBIM
Articles in this guide
This is the first part of a guide to improving OpenBIM with Autodesk Revit. Subpages are the following:
Setting up IFC class mappings
IfcGrid
Structural Connections
orIfcFastener
as relevant. Topography
is exported asIfcSite
IfcOpeningElement
IfcMember
, except forJoist
IfcWall
You can download it here:
or IfcGrid
See also: IFC classes
group, as shown below.
- The deprecated parameter
IfcSiteGUID
You can download them here:
Parameter expression
to IfcRoot.Description
Revit and IFC GlobalId
attributes
IFC GlobalId
values are not visible in Revit by default. This becomes problematic if users are trying to reference an object by its ID. The only way to see the GlobalId is to export your Revit model to an IFC file with the Store the IFC GUID in an element parameter after export
option enabled in File > Export > IFC > Modify Setup > Advanced
. This property can now be overridden, copied, or searched for. If the text is deleted, it will be rewritten on your next export. However, it will always rewrite the original GlobalId
, as it is predetermined inside Revit. There is no way to regenerate a fresh ID for an existing Revit object.
This UniqueId
and the 8 character ElementId
attribute.
External References
