FreeCAD
Website: | freecadweb.org |
Source: | Github |
License: | LGPLv2-only |
Bugs: | report bugs |
Community: | Forum Mastodon Twitter Discord |
Donate: | donate |
This is the front page of a series of pages about FreeCAD
Subpages
Introduction
External pages
- Youtube BIM Workbench tutorial playlist in Portuguese (turn on subtitles)
- The BIM Workbench
