Revit setup for OpenBIM/Revit IFC import pitfalls
Mandatory conditions
Having an IfcBuildingStorey
, IfcBuilding
, IfcBuildingStorey
or IfcSpace
Geolocation / Model far from origin
Revit has currently no option to choose which base point an IFC model should be positioned by, it will be placed at the internal origin. If the IFC model is placed to far from this origin, Revit will not import your model correctly. Although in any software it is not a good idea to have large coordinates. Use relative placement as much as possible.
You might be able to see the model by linking the IFC instead of importing it, but if the coordinates are large (world-coordinates) the IFC needs to be pathced before it kan be linked in to Revit. This can be done in BlenderBIM:
x, y, z, rotation
IfcSpace
When linking IfcSpace
Workarounds
References
