IFC - Industry Foundation Classes/IFC concepts/IFC sequence concepts
- IfcWorkCalendar
- IfcWorkControl
- IfcWorkPlan
- IfcWorkSchedule
- IfcRelSequence
- IfcTask
- IfcTaskTime
- IfcLagTime
- IfcTaskType
- IfcEvent
- IfcProcedure
- IfcTask: Object Typing. Looks complicated.
- IfcTask: An IfcTask may in turn nest other IfcTask, IfcProcedure or IfcEvent entities.
- IfcTask: IfcTask's can be triggered or can trigger IfcEvent's, which is also defined through the relationship IfcRelSequence.
Source: IfcWorkSchedule
A project may contain tasks
Source: IfcWorkPlan
A work plan may contain tasks
Source: IfcWorkPlan
A task may contain subtasks
Source: IfcTask
Source: IfcTaskTime
Source: IfcTask
Source: IfcLagTime
Source: IfcProcess
Tasks may consume resources
A task consumes resources.
Source: IfcTask
Source: IfcTask
A task may contain properties
A task may contain properties. Typically this is used for risk assessment. For logistic tasks, it may also contain properties for packing instructions.
Source: IfcTask
Source: IfcTask
A project task may be based off a typical task type or template from a library of tasks
Source: IfcTask, IfcTaskType
A task type can nest a task type
Source: IfcTaskType
Source: IfcTaskType
A task type can nest a task, that is also typed
Source: IfcTaskType, IfcRelDefinesByObject
When a task type is used in a project, its child tasks are linked to the project tasks
A product type may be able to perform procedures
Products which have capabilities can describe the procedures they are capable of. These procedures may later on be linked to events to program smart building capabilities and reactions to their surroundings.
Source: IfcProcedure
A product may inherit procedures from its type
If a type has procedures, then all of its product instances also inherit all of its procedures.
A product type may have events that can trigger procedures
Product types may have events which trigger procedures. This is typically used in building operations and smart buildings.
Source: IfcEvent
A product may inherit events from its type
Products may also have events which trigger procedures. This is typically used in building operations and smart buildings. If a product type has an event type, it must inherit the event and its related procedures as well.
Source: IfcEvent
An event may be constrained to only trigger at certain times
A calendar may constrain when an event can occur. In this example, the motion sensor will only start monitoring for motion events during night hours. These night hours are defined by the calendar.
Source: IfcEvent
Warning or cautionary advice may be provided when tasks are to be performed
If an IfcProcedure has its appropriate PredefinedType set to an "ADVICE_*", then it may be attached to another process to describe warnings, caution, or additional information to be aware of when performing that task. This is typical in building maintenance works.
