MicroMVDs for exchange requirements
These *.feature
List of MicroMVDs
- Project setup MicroMVD
- Geolocation MicroMVD
- Model federation MicroMVD
- Element classes MicroMVD
- Geocoding MicroMVD
- Classification MicroMVD
- Naming MicroMVD
- Material MicroMVD
- COBie MicroMVD
Auditing BIM data with MicroMVDs
my_first_micromvd.feature
. Note that themyfile.ifc
file.
Execute BIMTester
Modifying a MicroMVD
If you know how to code, you can also define your own sentences. Read more in Developing custom MicroMVDs. MicroMVD
