Revit setup for OpenBIM
Revision as of 21:39, 15 August 2020 by Duncan (talk | contribs) (adding links)
Autodesk Revit does not come with strong official support for Industry Foundation Classes (IFC). This guidebook relies on Revit users using the revit-ifc open-source Revit IFC plug-in. Although the plug-in comes bundled with Revit, the bundled version is usually outdated and contains bugs that prevent basic functionality from working (such as the ability to assign IFC type parameters using the official shared parameters file). It is therefore a requirement for productive output to update to the latest version using the download links below.
Setting up IFC class mappings
You can download it here:
Setting up shared parameters
An example of IFC parameters in Revit
You can download them here:
Setting up psets in Revit
A starting template for Revit user defined psets can be found here: File:Revit-psets.txt
Revit and IFC GlobalId attributes
IFC GlobalId values are not visible in Revit by default. This becomes problematic if users are trying to reference an object by its ID. The only way to see the GlobalId is to export your Revit model to an IFC file with the Store the IFC GUID in an element parameter after export option enabled in File > Export > IFC > Modify Setup > Advanced window, as shown below. It is highly recommended that this option is always enabled.
After your export is complete, you can now see a new parameter called IfcGUID for your objects as shown below. Despite the inconsistent naming, this is actually the IFC GlobalId. This property can now be overridden, copied, or searched for. If the text is deleted, it will be rewritten on your next export. However, it will always rewrite the original GlobalId, as it is predetermined inside Revit. There is no way to regenerate a fresh ID for an existing Revit object.
# 1W_HslFTT2WwXj91DxSWxH
