AutoCAD
Revision as of 16:51, 7 March 2023 by Infeeeee (talk | contribs) (→Accessing data in AutoCAD via free software)
AutoCAD is a 2D/3D drafting software developed by Autodesk.
A good place to look for alternatives is https://alternativeto.net/software/autocad/
Getting data out of AutoCAD[edit]
File formats[edit]
AutoCAD has industry specific versions, called verticals, some formats are supported only by one of them
- DXF - Recommended, although not every features can be saved
- DWG - Everything is saved, but not readable by other applications
- IFC - Only in AutoCAD Architecture, Civil3D and MEP
Accessing data in AutoCAD with free software[edit]
- Speckle has an AutoCAD connector
- CADPythonShell is an AutoCAD addon for running python code inside AutoCAD. It uses IronPython, MIT license
- AutoCAD Civil3D comes with Dynamo since version 2022. Data in other verticals can be accessed via .NET interop services, more info in this forum
Limitations[edit]
Dynamic block custom parameters are not accessible via any method, and not readable from dxf files, visual representation are saved though. This data can be exported with DATAEXTRACTION command to csv or xls files.
