IFC - Industry Foundation Classes/IFC concepts/IFC sequence concepts
- IfcWorkCalendar
- IfcWorkControl
- IfcWorkPlan
- IfcWorkSchedule
- IfcRelSequence
- IfcTask
- IfcTaskTime
- IfcLagTime
- IfcTaskType
[edit]
Source: IfcWorkSchedule
[edit]
Source: IfcWorkPlan
Source: IfcWorkPlan
This same inheritance applies to procedures and events.
Source: IfcTask
Source: IfcTaskTime
Source: IfcTask
Source: IfcLagTime
Source: IfcProcess
A task consumes resources.
Source: IfcTask
Source: IfcTask
A task, event, or procedure may contain properties. Typically this is used for risk assessment. For logistic tasks, it may also contain properties for packing instructions.
Source: IfcTask
Source: IfcTask
Source: IfcTask, IfcTaskType
Source: IfcTaskType
Source: IfcTaskType
Source: IfcTaskType, IfcRelDefinesByObject
