BlenderBIM Add-on/BlenderBIM Add-on Clash detection
< BlenderBIM Add-on
Revision as of 14:02, 27 July 2022 by Duncan (talk | contribs) (Duncan moved page BlenderBIM Add-on Clash detection to BlenderBIM Add-on/BlenderBIM Add-on Clash detection)
Description[edit]
BlenderBIM implements Clash Detection between IFC files.
External Resources[edit]
Blender BIM - Clash Sets shows the IFCClash tool from IfcOpenShell as implemented in BlenderBIM Add-on
Cómo detectar colisiones con BlenderBIM shows the process of importing two IFC files generated from ArchiCAD into BlenderBIM to execute a Clash Detection. After importing each IFC file into Blender via BlenderBIM, the Clash Detection tool generates a JSON file with all information on the clashing IFC elements. Afterwards, the JSON file is used to identify and select these elements. Note that both Blend files must be Linked.
IfcOpenShell code examples
