MicroMVDs for exchange requirements/Levels MicroMVD
Revision as of 23:42, 22 June 2021 by Moult (talk | contribs) (Created page with "The following MicroMVD vocabulary can be used to ensure IFC data includes grids. <pre> Feature: Levels In order to locate objec...")
Feature: Levels
In order to locate objects
For all model coordinators, costers, schedulers, and recipients of the final built environment
Levels must be present
Scenario: Ensure that levels are present
 * The building with name "{name}" contains storeys
 * A datum storey must not exist
 * All building "{name}" storeys specify an elevation for the SSL
 * All building "{name}" storeys specify an elevation for the FFL
Variable Example Description
{name} 123FOO The name of the building
