MicroMVDs for exchange requirements/Quantity take-off MicroMVD
- Concrete material: "Concrete" in IfcMaterial.Category
- Concrete construction method: Pset_ConcreteElementGeneral.ConstructionMethod
- Strength class: Pset_ConcreteElementGeneral.StrengthClass
- Compressive strength: IfcMaterial.Pset_MaterialConcrete.CompressiveStrength
Feature: Quantity take-off In order to cost elements For cost planners All elements need to have dimensional and cost-significant metadata assigned Scenario: All concrete elements are named and contain data * All concrete elements must be assigned to a concrete material * All concrete elements must have their construction method assigned * All concrete elements must have their strength class assigned * All concrete materials must have their compressive strength assigned Scenario: All concrete element data must be in a standardised form * All concrete elements must have their construction method assigned with one of the following values: | Value | | In-situ | | Precast | | {value} | * All concrete elements must have their strength class assigned with one of the following values: | Value | | N | | S | | {value} | * All concrete materials must have their compressive strength assigned with one of the following values: | Value | | 20000000 | | 25000000 | | 32000000 | | 40000000 | | 50000000 | | 65000000 | | 80000000 | | 100000000 | | {value} | Scenario: All blockwork walls are identifiable * All blockwork walls must be assigned to a block material Scenario: All partition walls are identifiable * All partition walls must be assigned to a partition material Scenario: All walls must have dimensional quantities * All in-situ concrete walls must have a Length, Height, NetVolume, and GrossSideArea quantity * All precast concrete walls must have a Length, Width, Height, and GrossSideArea quantity * All blockwork walls must have a Length, Width, Height, and GrossSideArea quantity * All partition walls must have a Length, Width, Height, and GrossSideArea quantity * All other walls must have a Length, Width, Height, and GrossSideArea quantity
{file}
{schema}
Slabs
- In-situ concrete: Width, Length, Depth, Perimeter, GrossArea, GrossVolume
- Precast concrete: Width, Length, Depth, Perimeter, GrossArea, GrossVolume
- Other: GrossArea
Column
- Concrete: Length, OuterSurfaceArea, GrossVolume
- Steel: Length, OuterSurfaceArea, GrossVolume, GrossWeight
- Other: Length, OuterSurfaceArea, GrossVolume, GrossWeight
Beam
- Concrete: Length, GrossVolume
- Other: Length, GrossVolume
Other
- Footings: Length, Width, Height, GrossSurfaceArea, GrossVolume
- Railings: Length
- Piles: Length, OuterSurfaceArea, GrossVolume, GrossWeight
- Openings: Width, Height, Depth, Area, Volume
- Stair flights: Length, GrossVolume
- Structural members: Length, OuterSurfaceArea, GrossVolume, GrossWeight
- Reinforcement bar: Length, Weight
- Reinforcement mesh: Length, Width, Weight
- Curtain wall panels: GrossArea
- Window: Area
- Duct segments: Length, OuterSurfaceArea, GrossWeight
- Pipe segments: Length, OuterSurfaceArea, GrossWeight
Steel
painting type:
- none - architectural paint - fire resistant painting
grade - 250 - 300 - 350 - 400 - 450
brick wall
finish: - none - render - paint
block walls
thickness: - 90 - 190 - 390
core filled: - none - 1.2m - full height
load bearing: - yes - no
stiffeners (if not modeled): - yes - no
reo bars: - yes - no
partition walls
plasterboard layer: - impact resistant (yes / no) - moisure resistant (yes / no) - fire rated (yes / no)
Pset_WallCommon.LoadBearing – True/False Pset_WallCommonAcousticRating – Rw / Rw + Ctr Pset_WallCommon.FireRating -/-/-
