Tools
Geometry scanning
- Import image set.
3D Mesh modeling
Importing the point clouds
Geometry modeling
- Install BlenderBIM Add-on
BIM modeling
- Opt 1) Import a mesh file.
- Opt 2) Import a IFC file.
BIM modeling
- Open Draft Workbench.
- Arrange the Shape2DView projections in the 3D scene. Once you are done, you will not be able to move these projections anymore.
2D CAD documentation
This step is for generating PDF files for printing, with 2D CAD documentation (sections, elevations, etc) with FreeCAD. The idea is to work with these 2D drawings in a new and independent FreeCAD file (independent from the 3D models file) that is very light and can be shared easily.
- Create a new FC file.
- Alternative you can import the Shape2DView objects using App:Link option.
- Open Draft workbench.
- Save the file.
- Open TechDraw workbench
- Create a new page.
- Select a Shape2DView object or a group of them.
- Press TechDraw Insert View command
